Resistance to voltage output
Postby shanakaplus » Fri May 23, 2014 1:52 pm
Hi. I have fuel sensor which gives 240 -30ohm resistance output according to the tank fuel level. When tank is entry 240ohm resistance output and when tank is full 30 ohm resistance output. I want to convert this signal to voltage output such as when tank is empty 0v volt and when tank is full 5v volt output. My supply voltage is 12v. I am going to us this signal to my gps system. Please help me to design a circuit. Thank you.
shanakaplus
Re: Resistance to voltage output
Postby pebe » Sat May 24, 2014 3:21 pm
I assume you will want a linear relationship between resistance and voltage (is resistance linear with contents of the tank)?
What sort of accuracy are you looking for?
National Instruments cRIO-9035 8-Slot Mainframe Guaranteed *Ships Fast*
$1075.00
National Instruments cRIO-9035 8-Slot Mainframe Guaranteed *Ships Fast* pictureNational Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express
$435.00
National Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express pictureNATIONAL INSTRUMENTS NI PXIe-1084 MAINFRAME Chassis 158966C-01L w/ PSU, NO CARDS
$2987.00
NATIONAL INSTRUMENTS NI PXIe-1084 MAINFRAME Chassis 158966C-01L w/ PSU, NO CARDS pictureNI National Instruments 778643-01 Front Rackmount Kit for PXI - 8 Slot Mainframe
NI National Instruments 778643-01 Front Rackmount Kit for PXI - 8 Slot Mainframe picture
