MC Speaker to Bluetooth Switch
Postby AustinChopper » Tue Jun 03, 2014 9:50 pm
Newbie here so forgive if I post in the wrong spot for this forum. I'm looking for some help to build the following setup for my motorcycle.
CURRENT: Sound system plays directly to stereo speakers in my fairing.
WANTED: To be able to redirect the signal from the speakers to a Bluetooth transmitter using a switch that can be mounted inside the fairing (switch accessible externally but guts inside). I think a 4pol switch would do that however I would like to add a small led indicator that would let me know the signal is set to the "Bluetooth side".
Is there such a thing as a 6 pol switch or would I need an 8 pol because I would want to separate the led ground from the speaker ground? (due to the power)
Any help would be appreciated ! Thanks .... Nelson
AustinChopper
$27.04
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil
$38.44
12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil pictureDC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B picture
