Automatic Darkness Controlled Light using TRIAC and LDR
Postby robin007 » Fri Aug 01, 2014 3:59 pm
Based on a circuit I decided to make this work. Using a LDR and TRIAC to automatically control my outdoor light.
The Circuit diagram is as per the link below.[img]http://www.electronicsforu.com/electronicsforu/circuitarchives/my_documents/my_pictures/13F_1.jpg[/img]
But it is not working.. I used power supply of 4.5 Volts and Rest all the same . There was no change in the NOT gate output when there is change in intensity of lighting. But the Resistance varies from 10K to 180 K for Light to dark respectively. Any suggestions for this circuit...?
robin007
Re: Automatic Darkness Controlled Light using TRIAC and LDR
Postby pebe » Sat Aug 02, 2014 6:45 pm
Have you got a link to the circuit?
New Manual Coil Winder NZ-5 Handheld Coil Winding Machine Coil Counting Machine
$35.70
New Manual Coil Winder NZ-5 Handheld Coil Winding Machine Coil Counting Machine pictureCarrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX*
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureFactory Authorized Parts -Carrier 342813-75101 Replacement Coil Kit
$699.95
Factory Authorized Parts -Carrier 342813-75101 Replacement Coil Kit  picture1 Pole Air Conditioner Contactor 40 Amp 24VAC Coil Condenser Contactor...
$20.82
1 Pole Air Conditioner Contactor 40 Amp 24VAC Coil Condenser Contactor... picture
