CAN YOU PLUG 2 POWER SUPPLY UNITS ON 1 PC ???
Postby Ferden » Thu Sep 18, 2014 5:54 am
I have a pc that crashes quite often: the image freezes, if it was playing sound then the last frequency vibes forever, commands don't respond, and the only solution is reboot. I asked around and people told me maybe it's because of insufficient power supply, and after a check, it turns out the PSU output is in fact low for the hardware.
A new PSU is too expensive, but I also have a spare one. I always salvage everything, but is quite frustrating, 'cause you can have every piece of hardware you want, every object sold nowadays is designed to fail, be obsolete, be incompatible after few years.
As you know, no motherboard has 2 set of plugs for 2 PSU, and the motherboard is the one who manages the PSU: turns it on, off, and the like. But what happens if I simply duplicate the [url=http://pinouts.ru/Power/atx_v2_pinout.shtml]atx pinouts[/url] and plug some hardware on one PSU, and some in the other? Can it work or there are some problems I don't see?
Thank you
Ferden
$37.00
Raspberry Pi Compute Module 4 CM4 2GB RAM + Carrier Board pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureRAM Jack 10 Ton Capacity 10" Stroke Hydraulic Piston Frame Machines & towers
$274.99
RAM Jack 10 Ton Capacity 10Allen-Bradley 1775-ME8 Memory Module
$984.62
Allen-Bradley 1775-ME8 Memory Module picture
