LED Circuit 24 LED's
Postby prevan850 » Wed Sep 24, 2014 7:36 pm
I am making a circuit my constraints are space and shape of my circuit. I am basically making a ring (or a circle) of LED's, kind of like a flash light. My plan is to make an outer ring witch will be my positive lead in and that will run through 2 LED's in series. Then my inner ring will be my negative and lead back to my power source. I will have an array of 12 "2 LED" series in parallel. (i hope that makes sense). Anyway my question is what size resistor will i need. i believe i have done the math right.
What my circuit looks like (something like this but i will have 12 series and 24 LED's
------ LED---LED------ neg
pos ------- R ------ LED---LED------ neg
MATH
Power suuply = 12v
LED V = 3.2v
LED current = 20mA
R = (12-(3.2*2))/((0.020*2)*12)
R = 11.25 ohms
Wattage of resistor
w = (12-(3.2*2))*((0.020*2)*12)
w = 2.592 watts
so i would need a 2.59 watt resistor with 11.25 ohms of resistance
is this true?
prevan850
$29.99
Hydraulic Leveling and Slide Out Replacement Motor and Polarity Solenoid pictureCustom Dual Channel DC Test Control Box AC Powered Tested Working
Custom Dual Channel DC Test Control Box AC Powered Tested Working pictureMagne-Tron Instruments 700 ER Wafer Resistivity / Conductivity Tester Probe
$420.00
Magne-Tron Instruments 700 ER Wafer Resistivity / Conductivity Tester Probe picture
