Need to swap lcd screen for 3digit 7segment led display.
Postby Brits82 » Sat Oct 18, 2014 9:39 pm
Hi all.
I'm working on a project for my daughter and I would like to change the small LCD screen that displays 3 seven segmant digits for a 3 digit 7 segment LED display unit using the same input the LCD uses.
Is this possible? I have basic electronics experience and is completely self tought.
If you need further information I would try my best to provide it.
Thank you in advance.
Brits82
Re: Need to swap lcd screen for 3digit 7segment led display.
Postby KMoffett » Wed Oct 22, 2014 2:26 pm
I doubt that you will ever be able to do that. The display driving coding is totally different. Maybe a microcontroller decoding the LCD output and converting it 7-segment, but that would be a real challenge.
Tripp Lite LCR-2400 Automatic Voltage Regulator Power Conditioner - Outlets Work
$239.99
Tripp Lite LCR-2400 Automatic Voltage Regulator Power Conditioner - Outlets Work pictureMacurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller
$400.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 pictureAutomated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller
Automated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller picture
