Parallel MAC unit based on modified booth algorithm
Postby vanisha » Sat Nov 01, 2014 5:14 am
The below diagram is the parallel MAC structure. In parallel MAC both partial product addition and accumulation take place at same time.
[img]http://i.stack.imgur.com/aYJKo.jpg[/img]
The partial product summation + accumulation unit of above parallel mac is given below.http://i.imgur.com/Jd8WIyD.jpg (link to the image).
[img]http://i.stack.imgur.com/qIftF.jpg[/img]
My problem : When I give input to multiplier as 00000101(5) and 00001000(8) what will be the values produced, that can be used as input of partial product generation + accumulation stage. What will be the values of S0,S1,S2,S3 And N0,N1,N2,N3 in the second image? The complete document is shared below.
http://www.mediafire.com/view/zoh8zuand ... 7888_2.pdf
Please share your ideas.I need to continue my project based on your replies.
Thanks.
vanisha
$149.00
$565.00
$799.99
SOLAR ELECTRONICS MODEL 8012-50-R-24-BNC LINE IMPEDANCE STABILIZATION NETWORK pictureTOA ZM-104 Portable Analog Speaker Line Impedance Meter
$198.95
TOA ZM-104 Portable Analog Speaker Line Impedance Meter picture
