Motorcycle Start Button to Starter Solenoid Circuit
Postby Sportyrider » Mon Nov 17, 2014 1:37 pm
The circuit to engage the starter solenoid on my chopper failed inside the controller. So I would like some help on selecting the best way to get 12 volts at about 16 amps to the solenoid using a switch that is only rated at 250 ma that switches ground to the output. (I am guessing at the amperage using the fact that it has an 18 gauge wire carrying the load to the solenoid).
Thanks for any suggestions.
Sportyrider
Re: Motorcycle Start Button to Starter Solenoid Circuit
Postby KMoffett » Mon Nov 17, 2014 3:26 pm
What make/model motorcycle? Finding a wiring diagram will help.
Johnson Controls V-3974-1003 Actuator w 1/2" Valve Assembly
$70.00
Johnson Controls V-3974-1003 Actuator w 1/2JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureJohnson Controls A70HA-2C A70 Series 4-Wire 2-Circuit Temperature Control
Johnson Controls A70HA-2C A70 Series 4-Wire 2-Circuit Temperature Control pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$275.00
