merging rgb
merging rgb
Postby Gopostal » Fri Nov 28, 2014 8:58 am
Hi i am seeking help with a project
i am currently struggling to create a lightpainting tool that will automatically scroll through all the colours (RGB)
i have tried using rainbow merging LED's however they are not bright enough for my needs, to add to the difficulty the whole thing needs to be inserted into a 22mm pipe.
i have built a tool using a 3w RGB chip and a 3.7v battery then having 3 separate push to make switches red / green / blue.
this is nice and bright however i would like it to scroll through all the colours automatically.
the whole project is based on a tool created by Lenser called a V24 you could look on google to see what my aim is(they have stopped making them now)
thanks in advance
Gopostal :)
Gopostal
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureOEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690
$94.55
OEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style picture
