PWM on AC pump&heater using Arduino
Postby zhangxu92 » Tue Dec 02, 2014 4:20 pm
Hi, I'm working on a project where I will be using an Arduino to control the pressure of pump and the heating temperature of an Nespresso machine.
Its a Magimix M100 and will be running on UK Mains 230V 50Hz
Pump 60W
Heater 1200W
Right now I'm thinking of using a diode bridge and mosfet to do PWM since the pump rectifies the signal anyways.
[img]http://i.imgur.com/ApcT21i.png[/img]
I'm having troubles on which MOSFET I should choose as well as all the necessary passive components that is required to make such circuit work. Please give me some advice, would choosing something like IRF740B/IRFS740B [url]https://www.fairchildsemi.com/datasheets/IR/IRF740B.pdf[/url] work?
If so what values should I be careful with? And also would my circuit work at all (I think I need to add some resistor&capacitor on the collector of the optocoupler but not sure how)?
Thanks in advance!
edit: the mosfet in the diagram is suppose to be a N-channel enhancement MOSFET, accidentally chose wrong symbol
zhangxu92
Re: PWM on AC pump&heater using Arduino
Postby pebe » Thu Dec 04, 2014 6:36 pm
I looked around to find an optocoupler whose internal transistor could withstand peak mains volts (325V), but found none. But I did come across this opto-coupled triac driver that may be suitable. You could use it to drive a suitable triac.
http://pdf.datasheetcatalog.com/datashe ... zzwk7y.pdf
It's available here from BitsBox
http://www.bitsbox.co.uk/index.php?main ... ts_id=1368
Biddle Cat No: 220120 DC Dielectric Test Set 120Kv
$1650.00
Biddle Cat No: 220120 DC Dielectric Test Set 120Kv pictureSalisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel
$130.00
Salisbury 21405WT16 Dielectric Overboot 20 KV Size 16 17 Inch Tall, Deep Heel pictureLineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read Lot L
$54.95
Lineman Servus Super Dielectric Overshoes Mens Size 8 Brand New Read  Lot L pictureRFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114
$249.99
RFS Manual Grounding Jacket Striping TOOL RFS-916423 RFS 916423 JSTRIP-114 picture
