Schematic circuit xenon lamp
Postby tnnelectronics » Thu Dec 18, 2014 1:27 pm
Hi
I'm trying to repair an appliance for hair removal that uses a xenon lamp. (see attached)
Such devices called IPL, activate and deactivate the capacitors to discharge at predetermined time intervals, in order to have an effect of the pulsed light flashes and available energy in the shortest time.
I made the schematic but I can not understand the function of some signals, because the microprocessor control board is broken!
is just the functioning of PIN16 - PIN20 connector CONN1 ? (see attached diagram)
Best Regards
tnnelectronics
12 Pieces 10A10 10 Amp 1000V 10A 1KV Axial Rectifier Diode solar panel C16
$5.49
12 Pieces 10A10 10 Amp 1000V 10A 1KV Axial Rectifier Diode solar panel C16 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$9.55
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V
$11.95
4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V pictureMDQ400A Rectifier Diode, 1 Pcs Bridge Rectifier 400A 1600V Diodes, Black
$48.68
MDQ400A Rectifier Diode, 1 Pcs Bridge Rectifier 400A 1600V Diodes, Black picture
