Relay Help
Relay Help
Postby GDW » Tue Jan 06, 2015 3:49 am
First, I apologize that I am quite the newbie at fully understanding electronic circuits. I appreciate any feedback I might receive.
I am trying to build a simple circuit that can activate the shutter on a Canon DSLR. Building a standard wired shutter release is very straight forward as basically you are closing the ground loop on a 1/8' stereo plug. Usually there's 2 loops on the stereo connector rings; one for focus and one for shutter. But in my case the camera will be manually focused and stationary so it's just a matter of firing the shutter. No issue there. However I am trying to automate this process by using a control unit which serves standard 110V in timed intervals. I need a dry circuit for this so as to protect the camera from any DC current, but not sure exactly what type of relay I need. Basically I need to close the ground loop to activate the camera shutter when the controller receives a quick jolt of 110V. It also needs to be fairly fail resistant so I suppose an industrial-grade relay is best.
Again I apologize if I am not using the correct terminology or explaining clearly enough, but any help appreciated.
GDW
Re: Relay Help
Postby KMoffett » Tue Jan 06, 2015 2:37 pm
Can you post the Canon model #, and a link to the timer you plan on using?
Re: Relay Help
Postby GDW » Tue Jan 06, 2015 6:57 pm
Hi Ken,
Sure. Here's the remote circuit (and again I only need shutter release, not focus):
http://www.doc-diy.net/photo/eos_wired_remote/
And here's the controller I am using:
http://www.frightprops.com/controllers- ... -0913.html
GDW
Re: Relay Help
Postby GDW » Tue Jan 06, 2015 7:13 pm
By the way, there are similar controllers from this company with different output profiles, so I can also use something like this:
http://www.frightprops.com/controllers- ... oo-jr.html
GDW
Re: Relay Help
Postby KMoffett » Wed Jan 07, 2015 2:16 pm
Almost any mechanical relay with a 120VAC coil will work. The smaller the better.
15Values 750pcs TO92 Transistors Assortment Kit PNP NPN Bipolar, General Purpose
$9.22
15Values 750pcs TO92 Transistors Assortment Kit PNP NPN Bipolar, General Purpose picture3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3
$6.35
3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3 picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
Power Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82 pictureMJ15024 To-3 Silicone Audio Power Output Transistor 10 Pack
$39.99
