What's the difference between WS-C3650-48FS-L and WS-C3650-4
Postby Emma Jing » Thu Jan 22, 2015 5:55 am
Can somebody tell me what's the difference between these switches? Thanks.
The big difference between them is the former is '-L' while the latter is '-S'. -L means LAN Base while -S means IP Base. More product features below:
[url=http://www.router-switch.com/ws-c3650-48fs-l-p-5413.html]WS-C3650-48FS-L[/url] Overview:
PoE Switch
48 * 10/100/1000 POE+ Ethernet ports with 4 * 1G SFP uplinks
Layer 2 switching with limited static routing features
LAN Base IOS image with upgrade option to IP service (L-C3650-48-L-E) or IP base (L-C3650-48-L-S)
Up to 9 members stacking and up to 160Gbps of stack throughput
Dual redundant power supplies and fans redundant modular
[url=http://www.router-switch.com/ws-c3650-48fs-s-p-5459.html]WS-C3650-48FS-S[/url] Overview:
PoE Switch
48 * 10/100/1000 Ethernet POE+ ports with fixed 4 * 1G SFP uplinks
IP base image with update option to IP service (L-C3650-48-S-E)
Layer 3 routing features
Up to 40G wireless bandwidth per switch, up to 25 APs and 1000 Wireless clients for each switching entity
Emma Jing
Re: What's the difference between WS-C3650-48FS-L and WS-C36
Postby baileyjohn25 » Fri Feb 20, 2015 7:42 am
You already answered your own question... :)
baileyjohn25
LCD Digital Multimeter Voltmeter Ammeter Ohmmeter Volt AC DC Tester Lead Meter
$5.95
LCD Digital Multimeter Voltmeter Ammeter Ohmmeter Volt AC DC Tester Lead Meter pictureAnalog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt
$12.62
Analog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt picturePROGRAMMA SVERKER 750 RELAY TEST UNIT - Ammeter Not Working
$1799.10
PROGRAMMA SVERKER 750 RELAY TEST UNIT - Ammeter Not Working pictureLot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter
$79.00
Lot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter picture
