Photo interrupter help
Postby stoney1 » Sat Jan 31, 2015 12:54 am
I have a photo interrupter for a treadmill that has failed. Unfortunately I have not had much luck finding a replacement, the motor speed sensor is a Sharp GP1A05. Please see the attached illustration. My question to the forum is, are the voltage regulator, amp, gate, and npn transistor available in one ic.
Thanks for your time.
Jim
stoney1
Re: Photo interrupter help
Postby KMoffett » Sat Jan 31, 2015 11:18 pm
Never dealt with AliExpress (Alibaba)...but...[url]http://www.aliexpress.com/premium/sharp%25252dgp1a05..html?ltype=wholesale&isdl=y&SearchText=sharp-gp1a05.&src=sc&d=y&origin=n&productId=665065161&isViewCP=y&af=RelatedProducts[/url]
$5.99
$6.47
Cavitron power potentiometer for Gen 131, 132, 136, 137 pictureClarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT
$16.90
Clarostat RA20LASD103A 10K OHM Wirewound 10000 Ohm Potentiometer Industrial POT picture
