Transistor pinout
Transistor pinout
Postby [email protected] » Tue Mar 17, 2015 4:17 pm
Hello Electronic Circuits Help Forum,
With the flat facet of the TO-92 package facing you
and the three legs pointing down the transistor in the data sheet
http://www.nxp.com/documents/data_sheet/PN2222A.pdf
marked PN2222A has the collector on the left
the base in the middle and the emitter on the right.
https://www.fairchildsemi.com/datasheets/PN/PN2222A.pdf
marked PN2222A has the collector on the right
the base in the middle and the emitter on the left.
So do different manufacturers have different pinouts for
a transistor with the same name?
Is the base always in the middle?
Without the datasheet is there a way of knowing which
pin has which function?
Thanks.
Allen in Dallas
[email protected]
Re: Transistor pinout
Postby pebe » Wed Mar 18, 2015 4:21 pm
[quote]So do different manufacturers have different pinouts for
a transistor with the same name? [/quote]
Both the manufacturers you quote are using the same pinouts for the PN2222A.
[quote]Is the base always in the middle?[/quote]
There are other TO-92 pinouts that are different. Have a look at the 2N3902, where the base and collector are swapped over.
Postby KMoffett » Wed Mar 18, 2015 6:28 pm
I ran into this a while ago. The 2N2222A and PN2222A are one way...the P2N2222A is the opposite.
Note the drawing on the right side. [url]http://en.wikipedia.org/wiki/2N2222[/url]
But, if you do a Google search on the P2N2222A it's shown both ways. :(
National Instruments cRIO-9035 8-Slot Mainframe Guaranteed *Ships Fast*
$1075.00
National Instruments cRIO-9035 8-Slot Mainframe Guaranteed *Ships Fast* pictureNational Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express
$435.00
National Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express picture*TESTED* National Instruments NI PXIe-1062Q (Q for Quiet) Mainframe PXIe Chassis
$239.00
*TESTED* National Instruments NI PXIe-1062Q (Q for Quiet) Mainframe PXIe Chassis pictureNational Instruments NI PXI-1042Q Chassis / 8-Slot 3U PXI Mainframe. TESTED
$225.00
National Instruments NI PXI-1042Q Chassis / 8-Slot 3U PXI Mainframe. TESTED picture
