Help changing output polarity
Postby MrTinker » Tue Apr 14, 2015 1:22 am
never mind. this one post per day moderator crap is just plain annoying. take care.
MrTinker
Re: Help changing output polarity
Postby KMoffett » Tue Apr 14, 2015 2:44 pm
[quote]I would like to cut the enable pin which takes a positive input and somehow use a switched negative output from a 3 mode driver.[/quote]
Are you saying that you need an interface circuit to control the +enable pin by using the negative voltage from something else. What is the -voltage? Do they share a common ground?
Postby pebe » Wed Apr 15, 2015 9:14 am
[quote]....my posts must be read first before they appear, is there a way to expedite this?
It really slows down the process of figuring out a solution here lol.[/quote]
I'm afraid not. This procedure was introduced by the Admin to stop spammers who had plagued this site (and many others). After two postings by a new member, all further postings are not vetted.
It should not cause delay because I visit this site at least twice a day, and most days up to four times a day.
Postby pebe » Wed Apr 15, 2015 1:01 pm
[quote="MrTinker"]never mind. this one post per day moderator crap is just plain annoying. take care.[/quote]
You have deleted your original post, without bothering to answer Ken's question.
So can I assume your lack of patience and common courtesy means you are leaving us?
Left Right Heated Upper Mirror Glass for 2014-2021 Ram ProMaster 1500 2500 3500
$32.75
Left Right Heated Upper Mirror Glass for 2014-2021 Ram ProMaster 1500 2500 3500 pictureFor Dodge Ram 1500 09-18 5.7L Performance Long Tube Stainless Headers NEW
$236.59
For Dodge Ram 1500 09-18 5.7L Performance Long Tube Stainless Headers NEW pictureRevolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC
$449.95
Revolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit picture
