a hum filter for a 9vdc wall wart
Postby steve-kc7byp » Thu May 14, 2015 9:25 am
I have a Technosonic 900mhz cordless headphone set that I got at a yard sale. The cordless setup works works great on batterys. The base will also work off a 9vdc plus tip wall wart. I found a 9vdc plus tip wall wart in my junk box. It is the only 9vdc wall wart I have (period right now) with the right plug on it to fit the power socket on the base transmitter. The cordless headphones work on the wall wart. But there is a very loud hum there. That isn't there when the base is running on batterys. I think this wall wart is only half rectifying the a/c. I am a fixer, I can fix things but designing a circuit is a bit out of my league. I need some quick, smiple ac filter that I can build from parts in my junk pile to put inline on that 9vdc wall wart. I also have some old laptop style switching power packs that put out 12vdc. But I don't know the current draw of the cordless transmitter to compute the ohms and resistor size to drop the 12vdc to 9vdc. I could use some help on this proj please.
Steve
steve-kc7byp
Johnson Controls Metasys AS-UNT111-1 Unitary Controller - UNT 111-1
$35.00
Johnson Controls Metasys AS-UNT111-1 Unitary Controller - UNT 111-1 pictureJohnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B
$35.99
Johnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B pictureMetasys Johnson Controls (lot of 12) AP-VMA1420-0 coupling/bushing AP-VMA1410-0
$49.99
Metasys Johnson Controls (lot of 12) AP-VMA1420-0 coupling/bushing AP-VMA1410-0 pictureMetasys N30 Supervisory Controller Base Unit N2 Field Bus Ethernet MS-N301310-1
$320.00
Metasys N30 Supervisory Controller Base Unit N2 Field Bus Ethernet MS-N301310-1 picture
