Simple Logic Inversion Circuit?
Postby archie1234 » Sat Jun 27, 2015 4:50 pm
I need to make a simple circuit to remotely trigger this camera.
http://s1183.photobucket.com/user/mneme ... 3.jpg.html
Based on what I observed with my multimeter, the button on the camera is connected to "KEY" and "GND". A multimeter reading across the GND and KEY tabs pulls the signal from KEY from 3.3v to ground. I want to expose the ground and signal tabs from the button, and use an external signal to trigger the button press.
My problem is that the external signal goes HIGH instead of pulling low. It's a 3.3v output from my microcontroller.
How can I create a simple circuit which, when my microcontroller output pin goes to high, it pulls the KEY signal on the button to ground? (Ideally, in a simple and size efficient manner-- so not using a mechanical relay).
archie1234
Re: Simple Logic Inversion Circuit?
Postby KMoffett » Sun Jun 28, 2015 2:06 am
A logic level MOSFET (RFD14N05L of equiv.). Drain pin to KEY, Gate pin the the microcontroller output, and Source pin to the camera's and microcontroller's grounds.
Or an NPN transistor (2N3904 or equiv.) and a resistor (~10KΩ). Collector pin to KEY. The resistor between Base pin and the microcontroller's output. The Emitter to the camera's and microcontroller's grounds.
Lot Of 2 DELL PE1950 670W POWER SUPPLY 0D9761 0MY064 0UX459 0P424D 0HY105 0HY104
$30.00
Lot Of 2 DELL PE1950 670W POWER SUPPLY 0D9761 0MY064 0UX459 0P424D 0HY105 0HY104 pictureSorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply
$250.00
Sorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply pictureEMERSON SOLA SDP 5-5-100T POWER SUPPLY
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY pictureSilent Knight 5495 Power Supply SK-5495 Replacement Board - Used
$329.00
Silent Knight 5495 Power Supply SK-5495 Replacement Board - Used picture
