Need some help with an H-Bridge
Postby Seabottom » Fri Sep 25, 2015 3:50 pm
For a LEGO project I'm working on, I have some motors that draw too much power to be properly powered by my NXT unit.
To fix this I wanted to build an H-bridge to put in-between each motor and the NXT.
The output signal from the NXT is 9 volts which I want to use as the PWM signal
The motors require a 12 volts source which I want to connect to a wall outlet for a steady power supply.
Sometime ago, I had this schematic supplied to me and I simplified it a bit. I was told that I should calculate the resistor values myself but as I don't know how the formula goes I just went and got some 1k and 10k resistors.
[img]http://i.imgur.com/0khkjix.png[/img]
I put all the stuff on a breadboard and nothing worked. Measuring where the power was didnt' help. I think the transistors might not be working as I'm sure I connected them the right way around.
I did however put a + on input 1 and a - on input 2 and later I found out that transistors don't like negative voltage or something.
This was because I want to not only go forwards but also backwards with the motors. The PWM signal just inverts the + and - signal. I do not know how to achieve this, but I thought maybe adding some diodes to make the power run in only one direction, but then again I don't know where I would put them if I also needed to ground the setup and since ground changes the wire it runs in when the motor is running the other way, I just don't know.
TL;DR Need help making a PWM controller for a motor that will run both ways using the same input for forwards and backwards.
Seabottom
Re: Need some help with an H-Bridge
Postby pebe » Fri Oct 09, 2015 6:35 pm
Are you are using FETs for the transistors? Can you tell us their type?
The PWM is straightforward, but how do you propose to reverse motor direction - can you incorporate a single pole C/O switch?
Vintage elevator up and down call station with code blue key switch
$40.00
Vintage elevator up and down call station with code blue key switch  pictureVintage Canon Palmtronic LC-1 Pocket Basic Calculator w/ Small LCD Display
$120.00
Vintage Canon Palmtronic LC-1 Pocket Basic Calculator w/ Small LCD Display pictureVINTAGE GREEN METAL CASH DRAWER BOX
$179.99
VINTAGE GREEN METAL CASH DRAWER BOX picture1952 Navy Marines ZM-11A/I Bridge Capitance Inductance Resist Vintage Military
$600.00
1952 Navy Marines  ZM-11A/I Bridge Capitance Inductance Resist Vintage Military picture
