Remaing Charging Cycles on Rechargable NiMH AA 1.2V Batterie
Postby carloszoom3000 » Wed Oct 14, 2015 4:09 pm
I'm trying to find out the remaining charging cyles on NiMH AA 1.2V rechargable batteries.
I'm placing a battery in series with a the parallel of 3 resistors of 2.2 ohms which are 5, 10 and 20 watts respectively.
To log the discharge and using an Arduino UNO and with some visual basic code i can see on every second, the voltage values measured (it also shows a graph).
When checking a functional battery it takes 15327 seconds before the curve shows it's discharge and it takes 9000 seconds on the non functional.
I would like to know what parameters i should take into account to know the remaining charging cycles.
carloszoom3000
Re: Remaing Charging Cycles on Rechargable NiMH AA 1.2V Batt
Postby bwetman » Fri Oct 16, 2015 6:27 am
To estimate how much current the GPA draws can be quite difficult, depending on how accurate and detailed the information is that you’re after.
bwetman
Postby carloszoom3000 » Mon Oct 19, 2015 3:10 pm
Thanks for replying,
The ideal case would be to know the exact amount of remaining recharging cycles, but if it could be handled in percentage or even divided into let's say 10 levels (from 100 to 10) if battery remaining operating life, that would be ok.
carloszoom3000
$14.99
$38.99
25 Values Metallized Polypropylene Film Capacitor Kit 400V-630V - DIY Electronic picture120pcs Electrolytic Capacitors Kit Assorted 12 Values 1UF-470UF 16V 25V 50V US
$7.71
120pcs Electrolytic Capacitors Kit Assorted 12 Values 1UF-470UF 16V 25V 50V US picture925Pcs Aluminum Electrolytic Capacitor Assortment Kit 36 Values 1uF-1000uF
$45.99
925Pcs Aluminum Electrolytic Capacitor Assortment Kit 36 Values 1uF-1000uF picture
