Simple Photoresistor Circuit
Postby gwpmike » Sun Oct 18, 2015 9:08 pm
I want to create a simple circuit that is essentially the opposite of a dawn/dusk circuit.
A dawn/dusk circuit would allow a light to turn on (or close the circuit) when it is dark outside, and would turn the light off (open the circuit) when it is light outside. I want to do the opposite.
I want a LED to be able to turn on ONLY when it is light outside. I want the LED to not turn on when it is dark outside.
In other words, close the circuit when the photoresistor detects light, and open the circuit when the photoresistor does not detect light. Please see the attached diagram.
[img]http://i57.tinypic.com/303fdkg.png[/img]
gwpmike
Re: Simple Photoresistor Circuit
Postby Relayer » Mon Oct 19, 2015 6:51 am
[b]Hello gwpmike,
Please check the circuit below:
[img]http://i.imgur.com/qqG46bd.jpg?1[/img]
The above circuit will do what you want it to do, but it will be a gradual turn on and turn off, as the intensity of daylight and darkness changes progressively, so does the resistance of the LDR (Light Dependent Resistor).
I hope it helps.
Relayer [/b]
Relayer
EZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
EZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA picture200 Amp Transfer Switch, 48000W General-Duty Double-Throw Safety Switch
$104.99
200 Amp Transfer Switch, 48000W General-Duty Double-Throw Safety Switch pictureSensor Switch NPP20 PL nLight Plenum Plug-Load Control 120V, 20A
$29.00
Sensor Switch NPP20 PL  nLight Plenum Plug-Load Control 120V, 20A pictureBRIGGS & SRATTON Se Rated Automatic Transfer Switch 200 Amp 120/240V 1hp 071270
$585.20
BRIGGS & SRATTON Se Rated Automatic Transfer Switch 200 Amp 120/240V 1hp 071270 picture
