Split Voltage for Driver IC & Backlight
Postby AGS » Tue Nov 03, 2015 1:08 am
Let me start out by saying that I know very little about electronics.
I have an LCD module that displays time/temp and has a backlight. The backlight requires 3V whereas the driver IC only requires 1.5V. The power source is 2xAA batteries. There are 4 pins - 1&2 for backlight and 3&4 for IC. What are my options to connect the backlight and driver IC to the power source so that they both function properly? What's the most efficient option?
The backlight works when connecting 3V to pins 1, 2, 3, 4 but the time/temp is stuck on full display.
The time/temp display works when connecting 1.5V to pins 1&2 or 3&4 but backlight doesn't work.
Connected 3V to pins 1&2 and a separate 1xAA battery to pins 3&4 - backlight worked, time/temp stuck on full display, and 1xAA battery popped.
AGS
Re: Split Voltage for Driver IC & Backlight
Postby Relayer » Wed Nov 04, 2015 1:32 am
[b]Hello AGS,
Click on the link below:
http://i.imgur.com/ipofocc.jpg
A resistive voltage divider is crude, but should be adequate for what you need.
If you find that the back-light is a tad weak or not lighting, then change the value of the resistors to say 4k7. But make sure you change both, as they [u]MUST[/u] be of the same value. i.e. 4k7 and 4k7.
An active voltage divider would be much better, but since you're using such low voltages, it wouldn't work.
I hope the above helps.
Relayer[/b]
Relayer
Postby pebe » Sun Nov 08, 2015 3:39 am
AGS, can you provide a link to the module?
$25.00
$88.88
DCA55 Version Semiconductor Tester, Compatible with DCA55 Semiconductor Analyzer pictureLot Of 3 Lam Research 715-005844-001 Ring Orifice Semiconductor Equipment Part
$300.00
Lot Of 3 Lam Research 715-005844-001 Ring Orifice Semiconductor Equipment Part pictureSemiconductor Equipm. 24339-9.00 Dicing Tape, Clear, UV Curable, 9-inch, 3.3 mil
$180.00
Semiconductor Equipm. 24339-9.00 Dicing Tape, Clear, UV Curable, 9-inch, 3.3 mil picture
