ASSISTANCE PLEASE WITH DOOR CONTROL CIRCUIT
Postby ElectroMan283 » Thu Nov 19, 2015 6:28 pm
ASSISTANCE PLEASE WITH DOOR CONTROL CIRCUIT:
This is my door up/down control circuit. The DPDT switch acts as an upper and lower limit switch, which is great, except the door must go all the way to the top (or bottom) before DPDT activates and allows direction change via the Control Box. I need the ability to stop door, at any point, and reverse directions (up to down, or down to up).
I am assuming this would be done with relays, but… Can anyone help me accomplish this?
ElectroMan283
Re: ASSISTANCE PLEASE WITH DOOR CONTROL CIRCUIT
Postby pebe » Fri Nov 20, 2015 2:36 pm
You have not shown the existing circuit.
New Manual Coil Winder NZ-5 Handheld Coil Winding Machine Coil Counting Machine
$35.70
New Manual Coil Winder NZ-5 Handheld Coil Winding Machine Coil Counting Machine pictureCarrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX*
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureQDB-5A 100W Auto Actuator Drive Detector Ignition Coil PWM Signal Drive Tester
$56.99
QDB-5A 100W Auto Actuator Drive Detector Ignition Coil PWM Signal Drive Tester pictureFirst Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New
$449.99
First Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New picture
