LED Roulette Help (Sim & Breadboard)
Postby RuairiMonahan » Sun Jan 03, 2016 11:45 pm
Hello everyone,
This is my first post and hopefully not my last as I hope to reply and help those in need as I expand my own knowledge on circuitry (beyond that of fallout 4!). I have posted already on another website already.
I have a project which is due in a few weeks time (fast tracked course as we only received the assignment recently) and for my project I have chosen an LED roulette wheel with touch sensitive switch, which when triggered will produce the LEDs to light up one after the other until it stops on one random LED. I have researched several circuits (creating all of them on MultiSIM, which none of them worked exactly) and decided to focus on one particular circuit as I had the most success using MultiSIM (The LEDs spun once and the circuit crashed).
[img]http://www.555-timer-circuits.com/images/Roulette.gif[/img][url]http://www.555-timer-circuits.com/images/Roulette.gif[/url]
The above circuit is the one I chose. As this is a BTEC I cannot ask for help from the tutor however I am stuck in the mud right now (and usually I am quite good at building circuits both virtually and practically) as I cannot get the virtual simulation to work but more importantly I cannot get the circuit to work on a breadboard. Does anyone have any suggestions? I would really appreciate some help here and even a diagram of the breadboard just to help would be great also! Obviously I do not want someone else to do my project for me however a diagram or two would really help me as I am quickly running out of ideas and who better to ask than the experts?
RuairiMonahan
Re: LED Roulette Help (Sim & Breadboard)
Postby Relayer » Mon Jan 04, 2016 9:21 am
[b]Hello RuairiMonahan,
I did a mock up of the circuit you posted using Circuit Wizard 2 and it worked quite well. Though not in a pinwheel arrangement. Check the picture below:
[img]http://i78.photobucket.com/albums/j99/Riggon/Roulette%20Wheel_zps1duck5s3.jpg[/img]
One main problem with using either a 4017 or 4022 is their woeful pin-out arrangement. I try avoiding doing any circuits with either two of the Decade or divide-by-eight Counters. I think they were designed by a monkey or they are strictly to be used on double sided PCB's. They are a nightmare to wire on anything single-sided: PCB, Breadboard etc...
Do you have to do your project on the 4017, or can you use something else? Say a LM3914 10 LED Dot/Bar Display Driver IC instead?
Relayer
EDIT: You may notice I changed the values of C2 and R5. I upped C2's value to minimize the length of time of the pinwheel slowdown. I changed R5 to a lower value to make my LED's a tad brighter. But using the values in your diagram it worked fine.[/b]
Relayer
0.1Hz-100kHz Adjustable Frequency Generator 7.83Hz Schumann Resonance Generator
$17.94
0.1Hz-100kHz Adjustable Frequency Generator 7.83Hz Schumann Resonance Generator picture0.01Hz-200Khz Adjustable Frequency Generator for Healing Schumann Sine Waves Res
$37.99
0.01Hz-200Khz Adjustable Frequency Generator for Healing Schumann Sine Waves Res pictureSystem Sensor HWL-LF Low-Frequency Wall Horn White, 10-Pack
$397.00
System Sensor HWL-LF Low-Frequency Wall Horn White, 10-Pack pictureEVILEYE™ 432Hz / 528Hz Dual Frequency Giant Tuning Fork/Harmony & Love Frequency
$201.69
EVILEYE™ 432Hz / 528Hz Dual Frequency Giant Tuning Fork/Harmony & Love Frequency picture
