AC delayed off relay
Postby jack mcleod » Sun Feb 14, 2016 5:42 am
A ½ - ¼ sec. Delayed off of a 120v AC relay is needed. With a DC coil the cap goes in parallel. Can the delay be accomplished on an AC coil using a diode & a cap? If not how?
Thanks, Jack
jack mcleod
Re: AC delayed off relay
Postby KMoffett » Sun Feb 14, 2016 10:45 am
The short answer is no. DC relays depend in the coil resistance to limit the current. AC relays depend on the coil impedance at line frequency the limit the current. Applying DC to an AC relay will cause a much larger current to flow. which may cause excessive heating. And, even if that were tolerable, would require a much bigger cap to create any delay.
What are you switching on/off? Is powered hot and neutral still available at your switch after your load is turned off? There commercial Delay-off modules.
National Instruments cRIO-9035 8-Slot Mainframe Guaranteed *Ships Fast*
$1075.00
National Instruments cRIO-9035 8-Slot Mainframe Guaranteed *Ships Fast* pictureNational Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express
$435.00
National Instruments NI PXIe-1073 Chassis / 5-Slot PXIe Mainframe w/ MXI-Express picture*TESTED* National Instruments NI PXIe-1062Q (Q for Quiet) Mainframe PXIe Chassis
$239.00
*TESTED* National Instruments NI PXIe-1062Q (Q for Quiet) Mainframe PXIe Chassis pictureNational Instruments NI PXI-1042Q Chassis / 8-Slot 3U PXI Mainframe. TESTED
$225.00
National Instruments NI PXI-1042Q Chassis / 8-Slot 3U PXI Mainframe. TESTED picture
