transistors latching circuit problem
Postby The Night Whisper » Wed Apr 06, 2016 11:25 pm
Transistors latching cct
[/attachment]Hi all
I've made a latching switch using a transistors but it's not working as it supposed, and i don't know why
When pressing the push button the led is lit but it's not latched since it turns off when depressing the switch
pls help why it's not latching the output voltage?
The Night Whisper
Re: transistors latching circuit problem
Postby pebe » Fri Apr 08, 2016 3:46 am
There is nothing wrong with the circuit, it should work OK.
Check your wiring and connections. If all seems OK then you could have a faulty transistor. With the button pressed in, check that there is almost zero voltage between the emitter and collector of each transistor.
Will you let us know the outcome?
Postby PradeepKumar » Fri Aug 26, 2016 6:38 am
The circuit seems to be fine. All you need to look for is your connections.
PradeepKumar
MSA ALTAIR 4X Multigas Detector/Monitor for O2 CO H2S LEL w/ Charger
$99.00
MSA ALTAIR 4X Multigas Detector/Monitor for O2 CO H2S LEL w/ Charger  pictureMSA ALTAIR 4XR Gas Detector Monitor - ALTAIR 4XR
$750.00
$600.00
MSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026 picture
