reverse direction of dc motor with a switch or timer
Postby tpk » Mon Apr 11, 2016 7:09 pm
Hi there,
i have a 12v dc motor that i am using to spin a string from a fixed point (for a larger application). essentially, i need a switch or controller that allows me to change the direction of the motor after a certain amount of time, right before the tension of the string becomes too much and the motor fails. i don't know much about electronics and i'm wondering what is the simplest way to achieve this, and what products are there that can aid in doing this?
thanks for any help!
tpk
Re: reverse direction of dc motor with a switch or timer
Postby pebe » Tue Apr 12, 2016 1:55 pm
What length of time are you considering, and is the motor reversed continuously back and forth, or is a one-time reversal?
Postby tpk » Wed Apr 13, 2016 7:34 pm
hi, sorry for posting so many times! I'm new to this.
it would need to be a continual reversal. I am working to figure out the period, I believe it will be about 30 minutes each direction.
tpk
Postby pebe » Sat Apr 16, 2016 1:35 am
OK. Give me a few days and I'll sort something out for you.
Postby pebe » Sun Apr 17, 2016 2:39 pm
The simplest possible way would be to use one of those mechanical mains timers where 15minute segments can be turned on or off. You could set these to give successive periods of 30min on and 30min off. The output from the timer would energise a double pole changeover relay, that I could give you connections for.
Alternatively, you could use a counter IC to feed the relay. I have a suitable circuit, if you want it.
Postby PradeepKumar » Fri Aug 26, 2016 6:42 am
Pebe I agree with your suggestions. It seems to support the entire project for a DC motor with a timer or a switch control.
PradeepKumar
Postby awright » Sun Jan 07, 2018 1:21 am
You have not described clearly what the mechanical aspects of your winding up string device is, but presumably if the string can wind up to the extent of stalling the motor it is also either pulling tension on the string or torquing the far end of the string. If feasible in your application, can you rig up a set of contacts to sense the tension or torque and activate a relay or circuit to reverse the motor? Sensing torque would be best, since that could activate contacts specific to the direction of motor rotation.
Ideally you would use microswitches activated by the torque or tension to achieve positive transitions rather than simple contacts pushed together that can have noisy, tentative contact.
The simplest approach would be to have the switches activate a "latching relay" with DPDT contacts to reverse polarity of the power applied to the motor. You can purchase latching relays that rely on permanent magnets or mechanical latches in the relay or you can create your own by using a plain relay with a third contact to hold the relay closed. Circuit details are simple but would vary depending upon the type of relay and configuration of actuation contacts you employ.
awright
Postby KMoffett » Tue Jan 23, 2018 1:08 am
awright,
That thread was last replied to almost two years ago. You are creating a zombie. ;)
$53.99
Adjustable DC 0-30V/60/120V 0-3/5/10A Lab Power Supply Variable Bench Switching pictureEMERSON SOLA SDP 5-5-100T POWER SUPPLY
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY picturePhoenix Contact Power Supply MINI-PS-100-240AC/24DC/C2LPS (2866336) 24V
$100.00
Phoenix Contact Power Supply MINI-PS-100-240AC/24DC/C2LPS (2866336) 24V pictureMean Well RSP-320-24 Switching Power Supply 24v New Ship From USA
$40.00
Mean Well RSP-320-24 Switching Power Supply 24v New Ship From USA picture
