Circuit is short while multimeter reverse probing
Postby santhakumar » Wed Apr 27, 2016 10:54 am
In My design i have a super cap circuit..in it i can see some weird things happening.
it is 5V power rail..with multi meter impedance check with positive probe on 5V rail and negative probe on ground, i don't see any short ( it is around 12K ).
but when i probe negative probe on 5V rail and positive probe on ground i am seeing short (0 Ohm).
Does anyone faced this kind of problem.. Pls suggest me the reason behind this.
Santhakumar.
santhakumar
Re: Circuit is short while multimeter reverse probing
Postby pebe » Fri Apr 29, 2016 10:21 am
Is the multimeter a digital or an analogue type?
Postby PradeepKumar » Wed Jul 20, 2016 6:43 am
Can you post the schematic diagram as it is quite hard to explain without that.
PradeepKumar
Postby PradeepKumar » Fri Apr 28, 2017 11:28 am
Thanks for sharing nice information.
PradeepKumar
Postby PradeepKumar » Tue May 23, 2017 9:16 am
PradeepKumar
$57.99
Adjustable DC 0-30V/60/120V 0-3/5/10A Lab Power Supply Variable Bench Switching pictureSorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply
$250.00
Sorensen DCS 150-7 0-150V/0-7A Adjustable High Voltage Power Supply pictureEMERSON SOLA SDP 5-5-100T POWER SUPPLY
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY pictureSilent Knight 5495 Power Supply SK-5495 Replacement Board - Used
$329.00
Silent Knight 5495 Power Supply SK-5495 Replacement Board - Used picture
