64 to 6 decoder
64 to 6 decoder
Postby tnnelectronics » Mon Jul 31, 2017 9:31 am
I used 74HC137 to create a 6-to-64 demultiplexer following the schema on page 13 of the attached datasheet ...
Now I have to do the reverse operation, that is 64-to-6 ...
How can I do?
Thank you.
[url]https://assets.nexperia.com/documents/data-sheet/74HC137.pdf[/url]
tnnelectronics
$37.00
Raspberry Pi Compute Module 4 CM4 2GB RAM + Carrier Board pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureRAM Jack 10 Ton Capacity 10" Stroke Hydraulic Piston Frame Machines & towers
$274.99
RAM Jack 10 Ton Capacity 10Revolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC
$449.95
Revolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC picture
