Help identify TO-220 device: LC2K9 K9536 B11R6
Postby Alaskan » Wed Aug 28, 2013 3:24 pm
I have a TO-220 solid state device package marked with these three identifiers I am trying to find:
LC2K9 K9536 B11R6
So far, web searches do not turn up where I can find replacements or what the ratings are. They are used in a 48V LED repeater:
http://www.aliexpress.com/item/Max-24A- ... 27370.html
Can anyone help me get the specs on the TO-220 devices used in this unit? I can order a new one cheap enough but also want to know the power rating to determine if I can push the device a bit harder than specified if using a larger heat sink.
Alaskan
$35.70
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$67.44
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW pictureFirst Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New
$449.99
First Co 4HBC 400 CFM Fan Coil 2-Pipe 3 Row Chilled Water PSC Motor LH Brand New picture
