DC Adapter
DC Adapter
Postby kapilvs » Fri Apr 22, 2011 11:44 pm
Can any one tell me how to convert 12vdc 700mA to 10vdc 750mA
kapilvs
Postby admin » Thu Apr 28, 2011 1:50 pm
You should be using a DC-DC buck converter.
Go to www.national.com
You need to find a tool called Power architect.
Enter input and output voltages, you will be presented with a choice of different circuits.
Choose one which suits your efficiency requirements its (0.75*10)/(12*.7) = about 89%. You will get plenty of results with efficiency > 89%
regards,
Admin.
admin
Site Admin
Postby steveo » Sun Jun 12, 2011 4:19 am
You can use a LM7810 Voltage Regulator. Because you are droping the voltage 2 volts you can probable get the extra 50 mil.
http://platea.pntic.mec.es/~lmarti2/cir ... LM7806.pdf
Take care,
Steve O.
steveo
Postby Laptop Charger » Tue Aug 09, 2011 12:08 pm
For DC adapters for Laptop you can get from here. Visit our site and get compatible Laptop Adapters.
[url=http://www.everycharger.com/]Laptop Chargers[/url] | [url=http://www.everycharger.com/]Laptop Ac Adapters[/url]
Laptop Charger
$169.75
$500.00
Cooner Wire NMUF 2/30-4046SJ Ultra-Flexible Micro PVC Cable, Gray, 2C, 250 ft. picture1000Ft UL 8 Conductor Silver Satin Modular Cable Reel 26AWG
$337.04
1000Ft UL 8 Conductor Silver Satin Modular Cable Reel 26AWG pictureCommon Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned
$230.30
Common Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned picture
