speed control circuit. can I modify this circuit?
Postby jeffg » Fri Apr 29, 2011 3:02 pm
This is a pic of my makita sander polisher showing a pair of diodes that control the speed from 3800 rpm to 2000 rpm. I was wondering if I could add another diode to knock off a few hundred more rpm for polishing. I mainly use the polisher for automotive paint/ final buffing and a lower rpm would be better.
http://321mach123.fileave.com/makita.jpg
The diodes read S3V (an upside [u]L[/u] ) N
The motor is rated at 6.5 amps 700 watts.
Maybe somebody can look up a radio shack number as that's the closest store I'm near.
If anybody's interested I can post what materials I use for the help. I mainly hand polish using a two part system.
jeffg
$31.24
$6.35
3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3 pictureMOSFET Transistor Assortment Kit 50 Pcs 10 Values N-Channel P-Channel RoHS
$44.97
MOSFET Transistor Assortment Kit 50 Pcs 10 Values N-Channel P-Channel RoHS picture
