Part identification
Part identification
Postby dubyoo » Tue Jun 14, 2011 2:11 pm
Hi.
I'm in a bit of a pickle. I blew a resistor on a friends car stereo and can't work out which type it is.
It's the melted one in the pic. I've measured it as 2.0 x 1.0mm but the two closest dimensions are 0603 (1.5 x 0.08mm) and 0805 (2.0 x 1.3mm).
[img]http://i454.photobucket.com/albums/qq269/dubvoo/served/Snaps/SMD0res.jpg[/img]
My best guess is 0805. Or should I just get both?
Thanks.
dubyoo
Postby hypa_dude » Wed Jun 15, 2011 5:36 pm
If you get a 0805 it will just overhang the sides of the pads a little bit. Since the board has a solder mask, it doesn't really matter. It looks like those pads in the picture are a little wide anyway, so I'm pretty sure 0805 will work perfectly.
hypa_dude
Postby dubyoo » Wed Jun 15, 2011 7:23 pm
Cheers, dude.
dubyoo
And another..?
Postby dubyoo » Fri Sep 23, 2011 4:44 pm
Okay, I have a new one for you!
This is a component on a board out of a cigarette lighter + USB adapter.
It's copper-coloured inside with 4 black lines that run around the circumference, the body is about 4mm long with a clear plastic housing that has O, backwards E, C on one line and S (or maybe 5), T below.
Anybody have any idea what is and how to obtain specifications?
[img]https://dl.dropbox.com/u/3679845/1316795257325-1.jpg[/img]
dubyoo
Analog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt
$12.62
Analog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt pictureLot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter
$79.00
Lot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter pictureFCI DC Amperes Analog Panel Meter Ammeter Gauge Model/MPN D.C. AMPERES
$16.99
FCI DC Amperes Analog Panel Meter Ammeter Gauge Model/MPN D.C. AMPERES picturePrime Analog Panel Meter DC Amperes Ammeter Gauge 0-50A Model/MPN GA1
$22.99
Prime Analog Panel Meter DC Amperes Ammeter Gauge 0-50A Model/MPN GA1 picture
