heating element variable resisotr control
Postby hazebrewer » Fri Jun 24, 2011 10:40 pm
I have an immersible heating element that is controlled by a variable resistor. A separate toggle switch provides a hi and low setting. The device is 1800W and runs on 120 VAC. My question is: wht type of variable resistor might this be and where might I find a replacement?
Cheers!
hazebrewer
hazebrewer
Postby loupurdie » Sat Jun 25, 2011 4:39 am
We could attempt to control a DC motor with a variable resistor or a variable resistor connected to a transistor. But since it generates HEAT, it wastes power where PMW controls the motor by driving the motor with shirt pulses. This project controls a train motor.
Therefore the longer the pulses are (PMW) the faster the train would go.
I need to write a writeup regarding why i am choosing PMW controller over Resistor controller. Can anyone please recommend me a good site or a good book...???
[url=http://www.lets-do-diy.com/]DIY[/url]
loupurdie
Postby hazebrewer » Mon Jun 27, 2011 5:02 pm
There's more! This switch also has a built in temp enabling heat control from very low (100F) to very high 190F+.
Michael
hazebrewer
Postby Mike Paul » Sat Sep 03, 2011 10:09 am
Hello There
Electrical Elements that use their resistivity to control the amount of electric current that flows through they are called Resistors. An ideal resistor in an electrical circuit is a device which produces a linear relationship between the voltage applied across it and the current flowing through it.
Thanks and Regards
Mike Paul
Mike Paul
$139.00
Shark Stratos Cordless Vacuum, Clean Sense IQ & DuoClean PowerFins (Refurbished) pictureNEW Hoover CH93619 40V Cordless Backpack Vacuum MISSING BATTERY/ CHARGER & HOSE
$189.99
NEW  Hoover CH93619 40V Cordless Backpack Vacuum MISSING BATTERY/ CHARGER & HOSE pictureProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip
ProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip pictureCordless Vacuum for DeWalt 20V Battery,5 in 1 Handheld Electric Vacuum Cleaner
$54.90
Cordless Vacuum for DeWalt 20V Battery,5 in 1 Handheld Electric Vacuum Cleaner picture
