Equivalent suggestion needed
Postby debasisswan » Wed Jul 13, 2011 3:40 pm
Hi friends,
Could you please suggest equivalent of BD131 and BD132? I need them for a hobby project. a ultrasonic generator using 555, claimed to be useful to drive away stray dogs.
I did not find any datasheet for BD131 or 132.
Thanks in advance-
Debasisswan
debasisswan
Postby pebe » Thu Jul 14, 2011 5:48 am
Data sheet for the BD131 here:-
http://www.datasheetcatalog.org/datashe ... /BD131.pdf
Data sheet for the BD132 on the same site.
EQUIVALENT TRANSISTOR
Postby awesomeguy.arun » Mon Aug 15, 2011 4:25 am
[b]PLS HELP ME IN FINDING EQUIVALENT TRANSISTOR FOR "BD679"
pls pls pls :) [/b]
awesomeguy.arun
Postby pebe » Mon Aug 15, 2011 7:12 am
Awesome... , Welcome.
I have deleted your duplicate posting to the 'Newbies' forum because electric parts belong here in this one.
That said, you should have started your own topic labelled 'BD679 equivalent wanted', not just tacked your request on to the end of someone else's topic.
When looking for equivalents, it is always best to Google for an answer first. If you had done so then you would have seen a link to the OnSemi site that stated that a replacement for the BD679 is one of the MJE800 range. You can get the data sheets for them all at
'www.datasheetcatalog.org/datasheet/xxx'
as shown in the posting above yours.
Moderator
$149.00
$565.00
Ultrasonic Hardness Testercan ltrasonic contact impedance method to measure vari pictureData Inc Model 2124 Differential Amplifier High Gain High-Impedance Inputs
$211.95
Data Inc Model 2124 Differential Amplifier High Gain High-Impedance Inputs pictureSOLAR ELECTRONICS MODEL 8012-50-R-24-BNC LINE IMPEDANCE STABILIZATION NETWORK
$799.99
SOLAR ELECTRONICS MODEL 8012-50-R-24-BNC LINE IMPEDANCE STABILIZATION NETWORK picture
