How to Measure Internal Resistance?
Postby A123rc » Sat Nov 05, 2011 7:26 am
How to measure Internal resistance ?
As the resistance of a battery provides useful information about its performance and detects hidden trouble spots, I want to know how to measure internal resistance!
A123rc
Postby pebe » Sat Nov 05, 2011 12:36 pm
Connecting a load on to a battery will result in a fall in battery voltage. So you can calculate internal resistance like this.
If you measure the battery voltage with no load, and then measure the battery voltage and current drawn when loaded, the internal resistance of the battery will be:-
Difference between the two measured voltages/current
Hi
Postby aadambell » Mon Nov 14, 2011 7:20 am
<expletive deleted> Never thought while studying High School Physics all those years back that explaining Internal Resistance would be such an arduous task!
“The internal resistance of a battery can be calculated from its open circuit voltage, voltage on-load, and the load current. An equivalent series resistance meter as used to measure the ESR of capacitors, essentially an AC milliohm meter, can be used”.
aadambell
Postby pebe » Mon Nov 14, 2011 8:38 am
aadambell,
An ac milliohmeter can only measure impedance of a capacitor, which is not the same thing.
To measure ESR you need to separate the resistive component from the reactive component, so you need a bridge or some way of measuring the impedance and its phase angle.
$27.04
$13.63
DC 12V 0.3A Solenoid Electromagnet Push Pull Type 5N 10mm Open Frame JF-0530B pictureSDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$375.99
