16 x 2 LCD Pins HELP!
Postby oiyela » Tue Mar 06, 2012 9:55 am
hi,
i am currently doing my third year project. i am building a portable patient monitor. For the display of the system i am using a 16 x2 LCD display. During the process of putting my parts together i realized PADS layout put the pins of the LCD the wrong way round instead of PIN14 - PIN1 it made the connections to PIN1 - PIN14 . i am just wondering if they make LCDs with the pins the opposite way if they do please advice where i can buy it in the uk or the name of it. i am tight on time and have already put all my parts in so starting again will be hell.
THANKS!
oiyela
Re: 16 x 2 LCD Pins HELP!
Postby pebe » Tue Mar 06, 2012 4:52 pm
What is the part number of the display?
$49.99
JOHNSON CONTROLS VALVE ACTUATOR  ‎3Nm (27in-lb)  /  VA9203-GGA-2Z pictureJohnson Controls EASYIO FW-08 WiFi BMS/BAS Controller - NEW
$129.99
Johnson Controls EASYIO FW-08 WiFi BMS/BAS Controller - NEW pictureJohnson Controls A421ABC-02C A421 Series, Electronic Temperature Control,...
$91.81
Johnson Controls A421ABC-02C A421 Series, Electronic Temperature Control,... pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$250.00
