Impact Sensor
Impact Sensor
Postby GreatGonzo » Tue Apr 17, 2012 7:38 pm
I am attempting to build a wireless impact sensor for a project I am working on. I have figured out most of the components that I need for a prototype, but I am stuck on the sensor itself.
I need a component that will be normally open, then momentarily closed when impacted. I would prefer the part to be solid state, or at the very least, have very few moving parts. I would also prefer not to get into accelerometers that have to have microprocessors and programming involved.
Any Ideas?
Thank you
GreatGonzo
Re: Impact Sensor
Postby pebe » Wed Apr 18, 2012 2:31 pm
What about a simple inertia switch - the sort used as a movement sensor?
$17.92
Philips ADVANCE AmbiStar RELB-2S40-N Replacement Ballast 40-Watt 2-Lamp T12 pictureTractor Ballast Box Heavy Duty 5.3 Cu Ft Orange, Black Or Green
$225.00
Tractor Ballast Box Heavy Duty 5.3 Cu Ft Orange, Black Or Green pictureADVANCE RL-2SP20-TP MAGNETIC FLUORESCENT BALLAST, 2-LAMP, T12 F20T12 20W, 120V
$40.50
ADVANCE RL-2SP20-TP MAGNETIC FLUORESCENT BALLAST, 2-LAMP, T12 F20T12 20W, 120V picturePhilips Electronic Ballast T12 Lamps 120V RELB2S40N
$9.83
