Help with TDA7468D
Help with TDA7468D
Postby PietjePuk » Fri Oct 05, 2012 6:44 am
Hello all,
Does anybody (still) have experience with the TDA7468. I hooked it up to the TWI interface of an ATMega1284P together wit a LM75 , but all data returned from the TDA7468 are 0's. I don't get any communication error. The LM75 using the same TWI routines is working propperly.
Can anybody help me?
Thanks in advance,
Piet
PietjePuk
$16.79
EEPROM BIOS USB Programmer CH341A + SOIC8 Clip + 1.8V Adapter + SOIC8 Ad Hot picture49PCS/pack Car Eeprom IC Chips Kits 24xxx 25xxx 93xxx 95xxx SOP8 TSSOP8
$46.20
49PCS/pack Car Eeprom IC Chips Kits 24xxx 25xxx 93xxx 95xxx SOP8 TSSOP8 picture4PCS SOIC8 SOP8 WSON Chip Programmer Probe Spring Needle Flash EEPROM Cable
$76.99
4PCS SOIC8 SOP8 WSON Chip Programmer Probe Spring Needle Flash EEPROM Cable picture4PCS SOIC8 SOP8 WSON Chip Programmer Probe Spring Needle Flash EEPROM Cable
$79.99
