looking for alternative to this component
Postby Ryoskatekov » Tue Jan 29, 2013 12:09 am
Hello, I recently bought an old audiometer (Realistic APM-100) (basically a panel meter with some other circuit board) and one of the Meters were well... "broken" from rust damage. I was looking around component parts websites and ebay and came across the exact same one [img]http://stores.goldeneagleradios.com/catalog/P-48N.JPG%20resized.jpg[/img]
But was complete rip-off at +$20....
then looking at this one,
[img]http://ecx.images-amazon.com/images/I/616wUTCxsFL._AA1100_.jpg[/img]
Since the lens its self is 45mm in dia I figured the meter inside would be about the same as the one I'm looking for
What I'm looking for is the Inside of the meter,the core of the thing its self (doesnt reallly matter about the casing), its about 23mm in width and needle is about 20mm long.
Ryoskatekov
Re: looking for alternative to this component
Postby Ryoskatekov » Tue Jan 29, 2013 12:53 pm
Nvm found one on amazon.... Amico 55x50 500uf should work....
Ryoskatekov
Postby pebe » Tue Jan 29, 2013 2:37 pm
Amico 55x50 500uf is a meter movement ? ?
Postby Ryoskatekov » Wed Jan 30, 2013 12:45 pm
[quote="pebe"]Amico 55x50 500uf is a meter movement ? ?[/quote]
It looks extremely similar to the realistic apm100 meter from plastic casing to coil and needle so i'll have to experiment... When it arrives I'll post the results here
Ryoskatekov
GE Sensing Panametrics CRS-05-MB C-RS-401 PAIR Ultrasonic Flow Transducer
$600.00
GE Sensing Panametrics CRS-05-MB C-RS-401 PAIR Ultrasonic Flow Transducer  pictureNOS YORK 025 29583 000 TRANSDUCER 0 - 200 PSI B94
$169.99
NOS YORK  025 29583 000  TRANSDUCER 0 - 200 PSI   B94 pictureSiemens 545-208 Analog Output Pneumatic Transducer
$550.00
Siemens 545-208 Analog Output Pneumatic Transducer pictureTUF-2000B Ultrasonic Flow Meter Wall-Mount Liquid Flowmeter TS-2 TM-1 Transducer
$244.49
TUF-2000B Ultrasonic Flow Meter Wall-Mount Liquid Flowmeter TS-2 TM-1 Transducer picture
