Please help me with the circuit and its components
Postby sunilsuta » Sun Feb 03, 2013 5:57 pm
I need a circuit which has 2 LED emitters coressponding to 2 LED sensors.emitters are kept at one side and sensors at one side.emitters and sensors are 3 to 4 feet apart.emitters are supposed to emit IR rays contineously which is sensed by sensors.if the beam is broken the output at sensing end should go high(to enough level to trigger a flip flop).and the output should be high as long as the beam is interupted.and it should go low when once the beam reappears.please give me the circuit diagram along with component names.its a battery powered system.
sunilsuta
$173.56
EZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA picturePower Sentry PS1055LCP LED Emergency Driver Inverter Battery Backup
Power Sentry PS1055LCP LED Emergency Driver Inverter Battery Backup pictureUsed - RV 30A 50A Amp Inverter Generator Parallel Companion Kit 125V 30 50 AMP
$49.99
Used - RV 30A 50A Amp Inverter Generator Parallel Companion Kit  125V 30 50 AMP picture
