Inverted NC/NO Relay
Postby JoshMac » Fri Oct 25, 2013 12:52 pm
Hi Everyone,
I had a circuit board professionally made a short while ago, and while I was designing the board I have accidently switched a relays NO & NC contacts.
I have attached 2 pictures showing what I am looking for.
[/attachment][attachment=0]
Can any one tell me if any relays are actually manufactured like that? If the do exist, is there a special name for them?
Thanks in advance,
Josh
JoshMac
Re: Inverted NC/NO Relay
Postby takagari » Mon Oct 28, 2013 1:56 am
Not that I've ever seen :(
But you could lift the relay a bit and run wire's under to cross them, or on the back side of the board cut the trace and run a wire to the next contact in the proper order. It's not pretty, but works. I've seen this done on 50,000$ air craft circuits when they implement mods :)
takagari
$49.99
JOHNSON CONTROLS VALVE ACTUATOR  ‎3Nm (27in-lb)  /  VA9203-GGA-2Z pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureJohnson Controls T-5800-1 Pneumatic Receiver Controller
$700.00
Johnson Controls T-5800-1 Pneumatic Receiver Controller pictureJohnson Controls P45NCA-12 Lube Oil Protector. New In Box.
$129.00
Johnson Controls P45NCA-12 Lube Oil Protector. New In Box. picture
