DIP Circuit Alternative to PCA9547D SOIC Chip
Postby mfad » Wed Jul 23, 2014 10:45 pm
Hey,
I was wondering if you guys could lend a helping hand on one of my problems or at least send me in the correct direction.
I am trying to redesign a circuit and one of the components being used is a:
PCA9547D 8-channel I2C-bus multiplexer
Datasheet: [url]http://www.nxp.com/documents/data_sheet/PCA9547.pdf[/url]
This chip is a SOIC and I would rather use a DIP multiplexer with the same functionality. It would allow for accessibility and easy integration.
Is this feasible? Are there alternatives? How do I go about this problem? Any help you could offer would be great!
Thanks!
mfad
ASCO HV2647003 Solenoid Valve 3/8” 24 VDC (Box 26-063)
$80.00
ASCO HV2647003 Solenoid Valve 3/8” 24 VDC (Box 26-063) pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureNEW NUMATICS 11SAD411EE000061 SOLENOID VALVE 150PSI WITH 226-411B 24VDC 6 WATTS
$50.00
NEW NUMATICS 11SAD411EE000061 SOLENOID VALVE 150PSI WITH 226-411B 24VDC 6 WATTS pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW picture
