Is the capacitor destroyed?
Postby George1000 » Sun Oct 26, 2014 6:27 pm
On the picture you can see a ceramic capacitor, that is black on its top. Does that mean that it has been destroyed, or can I use it?
George1000
Re: Is the capacitor destroyed?
Postby pebe » Mon Oct 27, 2014 4:42 pm
No, it's not damaged. The dab of paint in that position indicates its temperature coefficient.
Black indicates a value of zero. If it were in lettering it would be shown as NP0.
Zero temperature coefficient means that its value is very stable; so its capacity will not change with changes of temperature.
I hope that helps.
Postby George1000 » Mon Oct 27, 2014 6:41 pm
Thank you very much!
George1000
$14.99
$38.99
$45.99
925Pcs Aluminum Electrolytic Capacitor Assortment Kit 36 Values 1uF-1000uF pictureMotor Capacitor 400-480uF/Mfd 250VAC 50/60Hz CD60 Run Starting Capacitor
$16.72
Motor Capacitor 400-480uF/Mfd 250VAC 50/60Hz CD60 Run Starting Capacitor picture
