Current / voltage detection
Postby kenah » Sat Jan 24, 2015 8:39 am
What would output a digital signal to detecting the presence of voltage / current even if it were to be high?
kenah
Re: Current / voltage detection
Postby KMoffett » Wed Feb 18, 2015 2:35 pm
So you want an output to be ~0V when the input voltage or current is either 0V or 0mA? And the output to be +5V when the input voltage or current is "any level" greater than 0V or 0mA? What's the realistic maximum voltage or current? Are you talking AC or DC? And...since it might help us to know...what's the purpose of this project?
$1.80
$32.62
Rectifier Diode 10A 1000V Electronic Silicon Diodes 200pcs for 10A10 picture1N5408 Diode 1000V 3A [ for Rectifier, TTL, Arduino, Pi Projects ]
$11.18
1N5408 Diode 1000V 3A [ for Rectifier, TTL, Arduino, Pi Projects ]  picture20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set
$17.99
20 Values Diode Assortment Kit Rectifier Schottky Fast Recovery Diodes Set picture
