Solenoid constant time
Postby JardaK » Fri Mar 20, 2015 9:01 pm
I have a small problem.
Solenoid has a resistance of 14.2 ohms and an inductance 0.056H is connected in series with a resistance 2.2Ohm
Thus calculated is the Tau = L / R = 0,056 / (14.2 + 2.2) = 0.0034s
But the measured value is 0.02s
The measurement is done on an oscilloscope for resistance.
Source is a classic laboratory.
If I measure only air-core coil corresponds to the time constant.
How is it possible that tau is based on much more?
Solenoid Type:
[code] http://docs-europe.electrocomponents.co ... 01b732.pdf [/ code]
Thank you for your response.
JardaK
$16.79
$106.42
$170.00
SAMSUNG SPW2plus PROM/OTP/MTP PROGRAMMER C & H Technology* MISSING PARTS* pictureEEPROM BIOS USB Programmer CH341A + SOIC8 SOP8 Test Clip + 1.8V Adapter + SOIC8
$32.99
EEPROM BIOS USB Programmer CH341A + SOIC8 SOP8 Test Clip + 1.8V Adapter + SOIC8 picture
