Shaft encoders, tachs, madness...
Postby billydanger » Fri Apr 10, 2015 5:57 am
I have two motors with 0.5 inch shafts that I need to keep track of and compare during operation. Speed only, not angular position. What would be some likely culprits as far as abandoned equipment that I might be able to salvage something like a rotary encoder or tach?
Thanks in advance,
Billy Danger
billydanger
Re: Shaft encoders, tachs, madness...
Postby ramancini8 » Tue Apr 14, 2015 4:08 pm
Look at old printers which use shaft encoders to monitor print head position. You will need/want the associated circuitry.
Look at position control systems such as valve drivers, etc.
ramancini8
$139.00
Shark Stratos Cordless Vacuum, Clean Sense IQ & DuoClean PowerFins (Refurbished) pictureAmetek 240 Volt 50/60 HZ 3 Stage-By Ball Bearing Vacuum Motor
$140.00
Ametek 240 Volt 50/60 HZ 3 Stage-By Ball Bearing Vacuum Motor pictureIdex / Systec Vacuum Pump 9000-2115 bench tested and GUARANTEED to work.
Idex / Systec Vacuum Pump 9000-2115 bench tested and GUARANTEED to work. pictureHoover UH75210 MAXLife PowerDrive Swivel XL Pet Bagless Upright Vacuum Cleaner
$50.00
Hoover UH75210 MAXLife PowerDrive Swivel XL Pet Bagless Upright Vacuum Cleaner picture
