search for compatible Varistor replacement
Postby itaishi » Fri Apr 22, 2016 11:21 am
i need a new varistor insteed of a currpt one,
i cant find the exact varistor model.
original compenent:
the exact model is 14d681k-M
name Varistor
model 14d681k
max volt ac420v, dc560v
Varistor 680V
terminal volt and current (max v / a) 1120v, 50a
capacity 290pf
Watt 0,6 W
the problem:
i cant find the original.
my question:
is anybody know if this one, on the buttom, can replace it ?
its not look the same at all.
looks different size,
is the replacement suppose to do the exact functioning as the original?
the replacment:
http://uk.farnell.com/bourns/mov-14d681 ... dp/2078692
thanks in advanced,
itai.
itaishi
Re: search for compatible Varistor replacement
Postby PradeepKumar » Thu May 05, 2016 10:35 am
You can find the same one in any one of the online stores available as they can help in giving you a huge varieties of options.
PradeepKumar
$27.00
$469.95
$299.99
