Need motor timing circuit
Postby caltex » Mon May 21, 2012 12:40 pm
I am looking for a continuously running timing circuit that will run a 12v motor 1-4 times daily (number of runs to be input by user), length of motor run to be 1-30 seconds per operation (length of run to be input by user). Once set, all run lengths will be the same.
I am new to this forum and new to electronics. I am handy in a lot of areas but electronics has not been one of them. On a scale of 1-10, my knowledge of electronics is about a 2, so I will probably need a lot of hand leading. I know I am asking for a lot. If this is not what you guys do, I apologize now.
caltex
$173.56
2 AWG Gauge Copper Battery Cable Power Wire Car, Marine, Inverter, RV, Solar pictureWZRELB 2000W Pure Sine Wave Inverter 24V DC to 110V 120V AC Power Converter w...
$237.46
WZRELB 2000W Pure Sine Wave Inverter 24V DC to 110V 120V AC Power Converter w... pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
$49.99
Used - RV 30A 50A Amp Inverter Generator Parallel Companion Kit  125V 30 50 AMP picture
