strobe circuit controlled by dimmer
Postby DJ Higgumz » Mon Mar 12, 2012 4:06 am
is there some type of strobe device that adjusts the frequency by a sort of dimming of power? im building a simple dmx led strobe that controls the strobe by dimming the power to some sort of solenoid or whatever controls a strobe.
DJ Higgumz
Re: strobe circuit controlled by dimmer
Postby sheldons » Tue Feb 26, 2013 4:08 pm
heres a simple strobe using hi brightness leds.........
sheldons
$7.77
$400.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller pictureBierer Meters AV40 40kV Voltage Detector Non-Contact Audible/Visual Proximity
$300.00
Bierer Meters AV40 40kV Voltage Detector Non-Contact Audible/Visual Proximity pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
